It is currently Fri Aug 15, 2025 11:08 am
PostPosted: Sat Oct 18, 2014 5:04 pm
First name: Big
Last Name: Jim
OK , My weekend is consisting of the following . I have 14" delta bandsaw with 6" Riser . I have pulled out the 3/4hp Motor and replacing it with 3hp ....... "loud tool time grunt"
3/4hp is 1750rpm 3 hp is 3450 rpm so i have to change pulleys . Right now the motor pulley is 2-3/4" and saw pulley is 6"
Ok All you Mad scientist :twisted: mathematicians ...... whats my pulley sizes need to be to make the change here ?????
PostPosted: Sat Oct 18, 2014 5:15 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Currently your saw RPM is 802 to keep that RPM you can make the motor pulley about and 1.5 or play with the calculator I use to come up with 2 pulleys
http://gadi.agric.za/software/renting/pulley_calc.php
PostPosted: Sat Oct 18, 2014 5:21 pm
State: Tennessee
Right now your running about 825 rpm on your saw shaft, doubling your rpm looks like a 2" on the motor 8" on the saw shaft will get you 860....... :mrgreen: maybe you want to go a lot faster? http://www.csgnetwork.com/pulleybeltcalc.html
Me mother in-law gave me a very nice 1950 Delta 14" to which I added the riser and a 2hp Baldor motor it really :mrgreen: turned it around
PostPosted: Sat Oct 18, 2014 5:29 pm
First name: Big
Last Name: Jim
Faster not issue, MOOOOO POWWWEEEERRR BABBYYY laughing6-hehe
PostPosted: Sat Oct 18, 2014 6:17 pm
You don't want to go too fast. Wood cutting band saws work best at about 3000 feet per minute. 820 RPM is about where you want to be, 860 wouldn't be so bad.
I'm not a big fan of 1.5" pulleys on 3450 rpm motors, you don't have a lot of surface area for belt traction so slippage and vibration can be a problem. I would measure how big you can go on the driven side and size the drive pulley to that. If you can fit a 12" pulley on the driven side, you can keep the 2.75 pulley on the motor but you'll be a bit slow on the blade speed. Do they make an 11 1/2" pulley?
Oh, and Jim,
Don't let the smoke out of this one.
These users thanked the author StevenWheeler for the post: CraigG (Wed Oct 22, 2014 8:21 am)
PostPosted: Sat Oct 18, 2014 7:01 pm
First name: Big
Last Name: Jim
laughing6-hehe Maybe I leave it like it is and see how long it takes to smoke the rubber tires on the wheels laughing6-hehe
I can do an 8" drive wheel on saw easy enough
PostPosted: Sat Oct 18, 2014 7:28 pm
First name: Tom
Last Name: West
State: Nova Scotia
I agree with Steven.
If you can't get a big enough pulley on the driven element (the saw) you can put in an intermediate shaft with two pulleys or a stepped pulley between the motor and saw to get you there. This takes up some room and can be a bit more work to set up.
Tom
PostPosted: Fri Oct 31, 2014 2:08 pm
First name: Big
Last Name: Jim
Its Done ... I have a new motor for the belt sander . The repair company was able to pump new magic smoke in there for little over 100.00 and my 14" delta bandsaw with 6" riser kit went from a 3/4hp to 3 hp .
MORE POWER !!!!!!!!!!!!!!!!!
Keeping the Guards I have , the closest i could get was 896rpm should be just fine
ITS SAWDUST TIIIMMMMMEEEEE laughing6-hehe
Users browsing this forum: DennisK and 26 guests
